obx intake manifold info
hey tr i got another question for yall.
any one here used one of the obx sheet metal intake manifolds on their cars? my friend just installed a gsr head on his motor and is wanting to ditch his factory gsr i/m. i noticed from the pics on ebay theres no hole for the iacv but other then that? any thoughts?
cheers, tom
cheers, tom
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Sullivan Racing LLC
352-665-2496-Tom
the stock GSR manifold flows well and even has two sets or runners, the second set open when vtec hits allowing for air to enter faster. the stock manifold is good for up to 600hp. i'd get a bigger TB and a thermal gasket before i get a new intake.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
yes i just put mine on tonight. HUGE difference i got it to idle with no check engine lights my only problem is the iacv the water hose that runs into the fitv there is no nipple on that intake manifold to run that hose so i blocked it for the moment but im afraid thats not good it may build pressure on tat hose and blow up or something. so ima buy a fitting and try to loop the hose or somthing.
true, i was going to weld a nipple before the t/b on the i/c piping and another nipple on the i/m and run both hoses to the iacv, i figure thatll control the idle perfectly
Sullivan Racing LLC
352-665-2496-Tom
Sullivan Racing LLC
352-665-2496-Tom
true, keep me posted on how well they perform please!
Sullivan Racing LLC
352-665-2496-Tom
Sullivan Racing LLC
352-665-2496-Tom
umm no. i dont trust any of the cheapo turbo manifolds, they dont hold up very well to the length of time i run 1250deg egts for...
Sullivan Racing LLC
352-665-2496-Tom
Sullivan Racing LLC
352-665-2496-Tom
OBX pulleys are about the only parts I would buy from them lol Its a pulley, you cant screw that up too much unless its all unbalanced lol
"P
