obd1 to obd0 dizzy
Old Feb 5, 2010 | 03:53 PM
sullivanracing06's Avatar
Default obd1 to obd0 dizzy
a friend of mine has a obd0 ls in a ef and just bought a 95 gsr head, im doing the wiring on the car and im wondering if i can solder on the obd0 plugs on the obd1 dizzy and it still read rite to the pr4 he has controlling the motor. he has a 6al ing box and im planning on adding a msd pill box to actuate the vtec,
any help? thanks
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Feb 6, 2010 | 12:27 AM
custom240sx's Avatar
DC Crew Member #1
No it will NOT work, the obd0 dizzy has less teeth in it than the obd1 and newer dizzies.
Old Feb 6, 2010 | 04:32 AM
rangcrx's Avatar
engine building &best
the distributor his useing on the ls thats in the car now should work on his vtec i think with one of the post cut off,or sell the obd1 distributor and buy a 89-91 crx si distrbutor
i love AUTOZONE
Old Feb 6, 2010 | 05:14 AM
so he can use the obd0 ls dizzy in the 95 gsr head? he will have to cut off one of the dizzys mounting tabs?
Sullivan Racing LLC
352-665-2496-Tom
Old Feb 6, 2010 | 05:17 AM
rangcrx's Avatar
yes and you can sell the obd1 to https://www.tamparacing.com/forums/h...izzy-obd1.html
but b4 ya cut it off make sure the other 2 line up good,
i love AUTOZONE
Old Feb 6, 2010 | 03:45 PM
DC Crew Member #1
Ok here's the deal...
If you are using an obd0 ecu and obd0 distributor right now then NO absolutely NOT will a obd1 distributor work on that setup. It will bolt on but the electronics will NOT work.
From what I understand and what you wrote, it looks like the customer is doing ls/vtec. If they are going obd1 with the ecu then YES you can make the distributor work. If they stay obd0 the obd1 distributor will NOT electronically work. The tooth count inside of the distributor is different between obd0 and obd1/2 distributors.
Old Feb 6, 2010 | 03:52 PM
dippincrx's Avatar
save the s.o.h.c
either rig the odb0 ls to work or convert to odb1 (the official way)
Old Feb 6, 2010 | 04:05 PM
DC Crew Member #1
Yes, it will have to be and obd1 setup in order to run the obd1+ distributor. I will repeat, it WILL bolt on to the obd0 setup BUT will not electronically work.
Old Feb 6, 2010 | 08:05 PM
alrite, im just gonna keep my obd0 dizzy bc i already have the msd cap set up on that and i have a solid map on my turbo edit program for my pr4..
Sullivan Racing LLC
352-665-2496-Tom
Old Feb 6, 2010 | 09:30 PM
mtber's Avatar
Bad idea. Use an obd1 distributor & obd1 vtec ecu.
