where are the timing marks on an H22a
where are or what are the timing marks on a h22 motor....i need to know this asap so that i can get my car tuned right...thanx
if you can't beat me join me...& if you can beat me...DAMN!!!!!!!
IM not sureit might be on the tranny close to the headsome hondas have a rubber plug on the trannyyou remove it and there
is a mark on the flywheelwhen its at top dead center
813-377-5505
there are two UP arrows on the cam gears ... set them so there facing up now you will see holes in the cam holder and in the cam ... line the holes up and drop 5mm pins in. This will lock the top at TDC. Now there is a nut down on the block that you need to tighten to lock the bottom of the motor. Pick up a helms and youll see what Im talking about. Its on the acc side of the motor. There is also a mark on the fly wheel.. hope this helps.
-Mike
-Mike
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
