91 civic manual rack in a da
Old Feb 2, 2010 | 02:31 PM
sullivanracing06's Avatar
Default 91 civic manual rack in a da
just wondering if a manual steering rack from a ef civic will bolt/fit in a 90 integra (da)
any one do this before? will the inner/outer tie rods work?
cheers, tom
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Feb 2, 2010 | 04:40 PM
custom240sx's Avatar
DC Crew Member #1
They fit with stock DA outer tie rods but you have to use a spacer from 2 of the bolts if I remember correctly. It's written up on honda-tech
Old Feb 6, 2010 | 12:59 PM
2 of the bolts? which bolts? the ones that hold the rack up to the rear subframe?
which model opf the ef came with the manual rack?
cheers, tom
Sullivan Racing LLC
352-665-2496-Tom
Old Feb 6, 2010 | 03:40 PM
DC Crew Member #1
As far as I know all the EF's had manual racks but to be certain any basemodel EF will have it. I do believe it is the rear bolts but like I said check on honda-tech because I know there was a write up on it.
Old Feb 7, 2010 | 12:45 PM
alrite, ive been wanting to switch to the manual rack and ditch the pwr rack that s disconnected.
Sullivan Racing LLC
352-665-2496-Tom
Old Feb 8, 2010 | 06:28 AM
juiced2ndgenteg's Avatar
I put a manual CRX rack(pretty sure a 91 civic is the same) in my DA like 6yrs ago. I know it went smoothly, no major problems swapping them.
