need help with starter on eg hatch
Old Jan 23, 2010 | 04:28 PM
jon18y2's Avatar
Exclamation need help with starter on eg hatch
i did a whole swap with my eg 4 door put the single cam in the eg hatch 1 promblem it has is that wen i go to start it with the key it does everything but start the car so now i got a wire to the starter and start it by a switch instead of normally like i did in the 4 door/ lmk if u no
Old Jan 23, 2010 | 05:41 PM
thegoldenchild's Avatar
the ground going from the harness to the starter is bad or cut somewhere, if in orlando i can fix that for you
Old Jan 23, 2010 | 05:47 PM
rangcrx's Avatar
engine building &best
what ground?
i love AUTOZONE
Old Jan 23, 2010 | 06:15 PM
its pretty much ground till you crank the engine
Old Jan 24, 2010 | 01:09 PM
jon18y2's Avatar
do u think if i get a whole new wiring harness it would just make it work cuz my fan doesnt turn on i have it straight to the battery im tired of fucking with those wires so do u think best bet is to get a new wireing harness and i am in orlando if u no anyone with an obd1 single cam non v-tec harness lmk
Old Jan 25, 2010 | 06:23 AM
freakasis's Avatar
there is no ground going from the harness to the starter (why would the starter ground through the harness?) but if there was that couldn't be the problem because he can jump the starter and crank it up. however, it could be the ignition switch, fuse, clutch switch, or wireing.
"Black people can't be racist" - Some black guy.
