Need Help Jdm Itr
Need Help Jdm Itr
Ok So Im Planning On Bulding My Motor In An All Motor. But Im Really Not Into Taking It Completly Apart To Change To High Compression. So Wat Would Be The Best Thing To Do?? I Was Planning On Just Bulding The Head With Bc Stage 3 Cams. Aftermarket Springs, Retainers, Valves Head Studs, Itb And Other Goodies.. Some Suggestions???
if this is going to be a high-revving motor you have to build the bottom end. that will fail way before the head does. and if you want to gain even more compression then shave the head too.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
sounds likeee a plannnn lol thanks for letting me know.. but im not tryna really have ridiculously high numbers its my daily driver im just chillin.. if i was to do cams, cam gears, valves, springs, retainers, studs, light pulley, light flywheel, stage clutch, individual throttle bodys, walboro fuel pump, some rc fuel injectors, hows da numbers with that looking???
daily driver and ITBs dont go together....
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
