h22 in EG question. the more responses the better. EcU question
Old Dec 24, 2009 | 12:05 AM
4DRintegraT's Avatar
Default h22 in EG question. the more responses the better. EcU question
i got h22a1 in eg. okay i was told that the p13 ecu wont work for this. that i would have to get a gsr or b16. I went to see if the p13 would plug in and it did. well it plugged into my integra (which is just a shell) but the shit is the same. questin is . It pluged in which means it will plug in to the eg . will it work!??.... i know it has the lil black box on the bracket under the ecu what about that thing?... someone fill me in. please
Rep is Returned
Acura
Old Dec 24, 2009 | 02:04 AM
c5hatch's Avatar
well i have a h22 eg hatch..and it had a p13 and ran fine..i would run a p13 over a p30 or p72 ecu since a p13 the right ecu for your swap..but if you can get a p28 and get it chipped with at least a decent basemap you would be better off
92 eg hatch-dd
92 red eg hatch-slow
Old Dec 24, 2009 | 07:50 AM
KJ's Avatar
KJ
bored at work
The p13 ecu looks for the EGR and the p72/p28/p30's do not. If you are planning to get the car ecu tuned then just get the b series vtec ecu and have the maps tuned. That way you can delete the EGR stuff on the motor. I'm not even sure if you can chip/tune the p13 ecu's. The p13 ecu will run the car fine btw just have to wire in the EGR so you don't get the check engine lights.
Old Dec 24, 2009 | 09:12 AM
Blue92ludesi's Avatar
you can chip em but you cant datalog a p13 so its useless.
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
Old Dec 24, 2009 | 11:29 AM
good info. thanks guys. the ecu will be better then the stock p28 auto ecu
Rep is Returned
Acura
