jdm d15b swap which ecu??
im in the process of doing the swap and i need to know which ECU to use. My p28 or po8? i dont want any check engine lights on after the swap. i know the po8 is a 1 wire o2 sensor and the p28 is a 4 wire o2 sensor. If i just use the po8 ecu with the swap i should be fine right? no need to change anything over.
thanks tech's
thanks tech's
assuming you dont want to run a chipped ecu with the correct maps....p28 should be closer to the right thing
"Black people can't be racist" - Some black guy.
