Engine knocking? (d16)
Old Dec 15, 2009 | 02:39 PM
Jay813's Avatar
Unhappy Engine knocking? (d16)
I'll make this as short as possible, see if I can get pointed in the right direction...
Heard the engine knocking/tapping when at high rpm,noticed that the oil light was flickering, checked the oil and was really low, put 2 quarts right away, still knocking just not as much or as loud. went and had the oil changed, new filter hoping that 4 quarts would fix it. no luck still knocking at high r p m. low r p m or when cruising no sound coming from motor.
was told by a friend that the engine would need to be replaced
any better suggestions? or where i can find another d16y7/8? and how much will they go for?
thanks
Old Dec 15, 2009 | 03:13 PM
Red2GDSM's Avatar
In the making...
PMd
Originally Posted by solsi2000
does this magical box come with a pussy magnet?
Originally Posted by NISSAN
need to fill ur vtec fluid back up, thats why, its located in the back of the block, the little black box.
^^Lmao this shit was just funny
Old Dec 15, 2009 | 03:46 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
is it rod knock or valve tick? plus for the same price of a new motor you can just get yours rebuilt.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Dec 15, 2009 | 05:31 PM
thegoldenchild's Avatar
thats only if the crank is still good, if not then u need to take to machine shop or get anoher one, but yet still better to rebuild cause u never know what the motor you buy has gone thru. a jdm d15b vtec runs for $ 350 with low mileage and warranty.
Old Dec 15, 2009 | 05:38 PM
StreetBlitz's Avatar
B Tuned CRX
Open it up. Only way to tell for real. Saves $$ too.
Old Dec 15, 2009 | 06:18 PM
CRAWFORD BUILT
a good point on the crank. if it's a bad bearing it could have damaged it (assuming it's rod knock). and like GoldenChild said, you never know what a used motor has gone through, JDM or USDM. if you rebuild it then you'll have a brand new motor!
CRAWFORD BUILT
DC Crew Member #23
Old Dec 15, 2009 | 06:25 PM
Jay813's Avatar
thanks for your help, i would rather rebuild as i dont want to put another beatup motor and run into more problems later. ive had this car almost 10 years
996 civic) would like to keep it a few more....i just didnt know rebuilding would be cheaper in the long run...
Old Dec 15, 2009 | 06:32 PM
StrictlyBusiness's Avatar
Mr. Stealyogirl
When the light light comes on its usually to late. Sounds like you have a bearing going.
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Dec 18, 2009 | 08:22 PM
FrodoGT's Avatar
Found the Vtec switch.
Yeah your bearing will slowly have more material eaten off by the crank and the knocking will get louder and at a lower rshared_pm... you need a new crank and bearings, or a new bottom end entirely. For about the same price and work you can have the crank machined and run an oversized bearing, but with the availability of a d16 crank you might as well just pick one up and have it ready to go in.
TR Old Skool EF Crew #24
