12v comming from the ecu?
Old Dec 11, 2009 | 11:39 AM
freakasis's Avatar
Default 12v comming from the ecu?
chipped and vtec converted p06, honda manual says it should be putting out "appox. 5 volts" to the IAT sensor. i have a code for the IAT sensor and when i check it, the sensor measures bad (infinate resistance), but i get 12 volts from the ecu, not 5v. could this be what killed the sensor? or is it ok to have 12v instead of 5v? i dont want to replace it and have the new one get fried imediatly.
"Black people can't be racist" - Some black guy.
Old Dec 11, 2009 | 11:52 AM
custom240sx's Avatar
DC Crew Member #1
Yea you fried the IAT...needs 5 volts
Old Dec 12, 2009 | 07:21 AM
freakasis's Avatar
so the ecu is bad too?
Old Dec 12, 2009 | 07:39 AM
DC Crew Member #1
Shouldn't be...I've fixed many wiring jobs where people fried the IAT by putting the iacv wiring to it. ECU was always fine.
Old Dec 12, 2009 | 08:03 AM
freakasis's Avatar
ill go measure the voltage comming out of D15 and D22 at the ECU. but if it says 12v there it means the ECU is bad right? prolly means i fucked something up when adding the vtec parts.
Old Dec 12, 2009 | 08:12 AM
DC Crew Member #1
I don't honestly remember the pin locations but the iacv is 12v the tps is 5v and the iat is 5v...just check at the sensor's themselves.
Old Dec 12, 2009 | 08:13 AM
freakasis's Avatar
thats where i measured 12v at yesterday. that was with key on engine off.
Old Dec 12, 2009 | 08:16 AM
freakasis's Avatar
also the iacv and tps are working fine. no codes for them, just the IAT.
Old Dec 12, 2009 | 01:03 PM
DC Crew Member #1
Did you ever check?
Old Dec 12, 2009 | 04:16 PM
freakasis's Avatar
HAH! i must have never actually measured it at the ECU because when i did just now i got 5v. i had an issue with a bad multimeter and i know i tested it but it must have been with the bad one. and then i got the new one and only tested the plug. which was the wrong one. it was to evap purge plug. thanx for the help everyone. and thanx to econobox for pinpointing the prob is 2 seconds flat!
