should my fan blow on the engine or on the radiator?
i cant for the life of me remember what way the fan is supposed to blow.
my car is overheating constantly when im at lights.
right now its blowing on the engine
thats how its supposed to blow, air should come from the front bumper and out the fan to the engine. have you checked your radiator fluid levels, thermostat etc.?
ಠ_ಠ Haters gonna hate ಠ_ಠ
check your coolant level. also when your puttin coolant in squeeze the upper radiator hose and let all the air flow out of the coolant lines. If you have air caught up in there your car will get hot quick. Had the same problem with my eg coupe. Just check the coolant and squeeze the air out of the hoses you should be good to go. If not you got bigger problems lol
turned out to be a faulty radiator. i got my new one put in and no more problems.
i think the car overheated once and split the radiator at the bottom but it wasnt leaking bad enough to see it, then it just got worse and worse until i could finally see it leaking.
i warmed the car up and then let it sit for 10 min running and it didnt overheat so i think its all good.
