retarded retarded retarded car~~!!!
Old Apr 19, 2002 | 10:27 AM
Matt Vassallo's Avatar
lifelong learner
crank it over
spark
fuel injectors tick
fuel pump is on and it gets pressure
why is it not running
i already sang songs to it and told it i would stop saying hoa around it.
i told it to go to sleep maybe it hasnt woken up yet?
88dx crx --> z6 with y8 head manifolds header
rest in peace tim.
Old Apr 19, 2002 | 11:06 AM
Bill's Avatar
Livin' in Seattle
Have you run a compression check?
If the head was just recently installed have you checked cam timing?
Other than some form of massive compression loss or seizing I dont see why it wouldnt turn over if youre getting spark and fuel.
Old Apr 19, 2002 | 02:47 PM
letsrollagn's Avatar
BRT OVERKILL
Can you here it turn or nothing at all? p.s.your header IS one of those manifolds.....exhaust manifold
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
Old Apr 19, 2002 | 05:24 PM
topichikoludo's Avatar
Originally posted by "Someone"
Originally posted by Mr Self Destruct
please tell me you converted the wiring correctly...
hehehhehe That would be a VERY BAD thing
I'm not running in circles
I'm just cutting corners
Old Apr 20, 2002 | 11:19 AM
RONIN's Avatar
Tetris on a stick
are you firing in the right order? on the right stroke?
Eat a live toad every morning, and that will be the worst thing to happen every day.
Old Apr 20, 2002 | 01:10 PM
Bill's Avatar
Livin' in Seattle
damn good suggestion.
Check the spark plug wiring and make sure youve got them connected in the right firing order.
Just fixed a guys car the other week with the same problem. Easiest money I ever made.
Old Apr 20, 2002 | 09:18 PM
lifelong learner
we have turned the distributor 180 degrees and tried it also.
so i believe that would negate theproblem of whether or not you know the timing is off.
weve also siwtched the plug wires around in hopes maybe it would start like that
good old engine starting fluid in the throttle body is going to happen next .
i swaere to god ihate this car
yes we did the dx--->si wiring correctly but you know what
just because i touched it
its not going to run
just because i touched it i probably A.D.Ded the whole thing to hell
rest in peace tim.
Old Apr 20, 2002 | 09:30 PM
RONIN's Avatar
Tetris on a stick
is there gas in it (instead of sugar or water)?? ecu fuse? bad ecu maybe? too rich? what injectors are in it?
dont know if this would make a difference but are the injectors wired backwards? are the correct style (peak vs saturation)
