b20b or b18a cams... which are better for turbo/pwr?
Old Nov 29, 2009 | 11:10 PM
sullivanracing06's Avatar
Default b20b or b18a cams... which are better for turbo/pwr?
i currently am running a b20b w a 18g, 550s, custom turbo edit.
have a built ls on the stand thanks to last night and a 18pk, im gonna swap the b20b head over and im wondering which cam would be the better of the 2 options i have lying around, the b20b stock cams or the b18a1 stock cams? thanks tr!
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Nov 30, 2009 | 05:28 AM
KJ's Avatar
KJ
bored at work
B20b are slightly better than the b18a.
Old Nov 30, 2009 | 06:12 AM
custom240sx's Avatar
DC Crew Member #1
^ exactly...they have a tiny bit more lift.
Old Nov 30, 2009 | 03:00 PM
88_Hatchy's Avatar
I'm cooler than you
actually the B18b cams are more aggressive, neither will make much difference
Old Nov 30, 2009 | 03:17 PM
DC Crew Member #1
^ Actually not
BrianCrower.com - Brian Crower - BC - Acura Integra - B18A / B18B
Old Dec 1, 2009 | 11:11 AM
SLOASFUK's Avatar
yaaa boy fuk wat u heard
b18a sucks
b18b iight
b20 z ^same shit
researched this alot trust me
Old Dec 1, 2009 | 11:13 AM
DC Crew Member #1
Actually if you really want to get into the research aspect even brian crower has the wrong specs up for the cams. I have pulled apart 3 different b18b1 heads, 2 b18a1 head, and 1 b20b head. All had different combinations of cams. The markings were different on all cam shafts (except sometimes the intake cam was the same between the b18 motors)
Old Dec 1, 2009 | 11:17 AM
SLOASFUK's Avatar
it could be, but theres really no point in changing them!
go with stage 2 brian crower turbo cams!
now if you wanna take your motor to 10k go with stage 3 brian crower n/a cams on your turbo setup with dual stainless valve springs/retainers, ferrera stainless flat valves, and your good to go!
been there done that! ^ my current set up!
Old Dec 1, 2009 | 08:09 PM
im wanting to build my non vtec head as you styated, i had the ferrera valves, dual v springs n retainers planned, still unsure on which cams to buy, i was just wondering which cams (b18a or b20b) that i have lying roud for free to reinstall when i install the bottom end in the car..
Sullivan Racing LLC
352-665-2496-Tom
Old Dec 2, 2009 | 01:09 AM
DC Crew Member #1
b20b are a tad more aggressive...maybe the difference of 1 or 2 whp on dyno...nothing noticeable.
