pr3 ???
pr3 ???
b16a in ef. stock pr3. my rev limter is hitting at 7000rshared_pm...it should go to 8200. i checked for codes and it read...code 7 which is ETS (engine temp sensor)
does that sensor, which is on the back of my motor above the oil pressure unit, need to be plugged in. cuz the one on the head is plugged in
help plz!!
help plz!!
i think the sensor you are talking about is the knock sensor and only if your ecu suports it. but that has nothing to do with your code. (meaning you ecu doesnt suport it) you need to replace your temp sensor or the wiring from it to the ecu and you prob should go away.
"Black people can't be racist" - Some black guy.
help plz!!
help plz!!
