help! car wont go over 3500rpm
did you do the wiring to allow a b16 to run in that chassis? if not, that the map sensor could have been wired up in any of 1000 ways. get a multimeter and see if the wires end up at the right place at the ecu.
"Black people can't be racist" - Some black guy.
your car is in limp mode. unplug map and if stays running with it unplugged you have a faulty sensor, and yes it could be the dizzy as well
Not right now CHIEF.....I'm in the Fucking Zone!
The Hit Squad Member
well i fiugered out it was just the dizzy..changed it out and it runs perfect...no more check engine lights or anything..runs all the way out and pops vtec hard...thanks for all your help!
Theres Only One Way To Build A Car..Build It Right!
