can you make manual 92-95 windows power?
Old Nov 19, 2009 | 05:55 PM
JDM son!'s Avatar
Professional Hustler.
Default can you make manual 92-95 windows power?
Im thinking about buying a rsx dash into my EG and the only way i will do it is if i can use the rsx door panels. my hatch is a vx and everything is manual, what does it take to make my doors have power windows?
Thanks TR!
MONEY IS THE MOTIVE.
Old Nov 19, 2009 | 06:03 PM
mogo21's Avatar
Default here goes
yeah u can do it u need the power window motors and regulators and door panels and power switches , and u need to wire in some relays to regulate power to the switches /i personally dont think its worth it just more money especially when those shitty honda power window motor go bad , but thats what u need
Old Nov 20, 2009 | 04:23 AM
EconoBox's Avatar
Four Door Mafia
Find an EX coupe and grab all the wiring, motors, regulators everything you will need. Including the relay and fuses. They both go in the fuse box under the dash. Then just figure out what wires are what in the door and splice the RSX connectors onto them and magic! Power windows in an EG hatch and you get your RSX dash and door panels.
ECU Chipping, Tuning, Custom Wiring, and any other automotive needs. PM me for a quote.
Hmotors/Hondata/Hasport/JHPusa/PasswordJDM
stores. Most parts in stock or 1 day away!
Old Nov 24, 2009 | 07:36 PM
freakasis's Avatar
i got an ex coupe dash harness and un loomed everything. then grabbed the power window plug from the door side and started cutting till i had all the power window stuff separate. took about 5 minutes. you need that and everything from inside the doors (regulator, wires, latch, switches).
"Black people can't be racist" - Some black guy.
Old Nov 24, 2009 | 07:45 PM
TheRichMan's Avatar
isn't actually rich...
Ding ding ding. Oh and an rsx interior would be baller as hell.
Old Nov 25, 2009 | 12:20 PM
thegoldenchild's Avatar
rsx in a ef cause im gangsta like that, converting civics 24/7
Old Nov 25, 2009 | 03:18 PM
Tampa's_Slow_EG6's Avatar
Living in Black & White..
omg thats sexy... ^^
Old Nov 27, 2009 | 06:28 AM
SLOASFUK's Avatar
yaaa boy fuk wat u heard
no dash jim mount the cluster thats it!
