Long term affects of sucking up water in cold air
Old Apr 13, 2002 | 10:06 PM
Sleeping_92_SI's Avatar
I kill 32-bit ECUs
about a month ago i hit a big puddle of water and sucked up alot of it in my cold air. it bogged out and died on me after a couple minutes it started back up and all you could see was steam coming out the tailpipe ? it took another 20 mintes of running it till it ran normal. is there anything i have to be woried about now ???
any comments or suggestions would be helpfull
Anthony
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
Old Apr 13, 2002 | 10:13 PM
KJ's Avatar
KJ
bored at work
Well if it feels all right now then dont worry about anything. You should have changed your oil and spark plugs after it happened though.
Old Apr 13, 2002 | 10:23 PM
I kill 32-bit ECUs
yea i already did
nice to know for future purposes
Anthony
Bicycle: Kawi 636R.
Old Apr 14, 2002 | 11:40 AM
88EFSiR1J1's Avatar
alittle water is good for the engine it steam cleans the pistons and cyl. walls
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
Old Apr 14, 2002 | 06:06 PM
ackteggsr's Avatar
common misconception with cai. you have to suck up a metric amount of water for you to hydrolock your engine hope that helps
Old Apr 14, 2002 | 06:39 PM
I kill 32-bit ECUs
yea but what about the long term effects ???
Anthony
Bicycle: Kawi 636R.
Old Apr 14, 2002 | 10:39 PM
KJ's Avatar
KJ
bored at work
There really wouldnt be any long term effects. It is the short term effects like hydrolocking the motor that you need to worry about. If you havent noticed your car running any slower than you dont have anything to worry about now or later.
Old Apr 15, 2002 | 06:04 AM
Bill's Avatar
Livin' in Seattle
I beg to differ.
If you managed to suck up enough water so that it actually reached the combustion chamber youve put a hell of a lot of stress on the motor and definately decreased its lifespan to a point. Might want to keep your eye on compression. Ive seen two cases first hand now where the head gasket fails prematurely after a little run-in with water.
Old Apr 15, 2002 | 06:20 PM
I kill 32-bit ECUs
fuuuccc didnt want to here that. but thanks for being honest.
ill get a compression check in a few weeks (or when i get the money which ever comes first)
thanx
Anthony
Bicycle: Kawi 636R.
