Speedometer And Miles Problem????
Old Nov 16, 2009 | 08:27 PM
DA-TYPE-R's Avatar
Exclamation Speedometer And Miles Problem????
My Eg Cluster Has Sumthing Wrong Wit It. The Miles Have Stopp, Nd The Speedo Dsnt Work, Im Sure Everyone Has Had This Problem Before
Wat Can The Problem Be? Nd Can Anybody Fix This For Me , I Will Pay
Old Nov 16, 2009 | 09:34 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Vss
-Winston Churchill
Old Nov 17, 2009 | 04:05 AM
Invader_Zim's Avatar
Typical TR Asshole
+1 check the connector first cause that might be loose or messed up but it's most likely going to be you speed sensor
ಠ_ಠ Haters gonna hate ಠ_ಠ
Old Nov 17, 2009 | 05:50 AM
K20A2's Avatar
Check for any frays/cuts in the wiring harness coming off of the VSS, it's located on the back of your transmission and held on with a couple bolts. If that checks out good, make sure the connector is plugged in and didn't come loose.
-Winston Churchill
Old Nov 17, 2009 | 05:52 AM
DRMORTY's Avatar
Once Ruled The World .l..
VSS(vehicle speed sensor), Speedo Cable or Cluster...
Start by checking the Cable and connections
TR
"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
Old Nov 17, 2009 | 06:22 AM
DA-TYPE-R's Avatar
well i changed the cluster ,nd i dnt think its the cable so, it might jus be the vss
