Help Read Pls !????
Old Nov 15, 2009 | 06:47 PM
Arcangelff7's Avatar
am selling the motor not the car
Old Nov 15, 2009 | 07:18 PM
thegoldenchild's Avatar
check codes so we can further assist you
Old Nov 15, 2009 | 08:22 PM
PAPICHULO787's Avatar
check tps
Old Nov 16, 2009 | 11:34 AM
codes ????
Old Nov 16, 2009 | 11:35 AM
tps ill check that !?
Old Nov 17, 2009 | 09:45 AM
alwayzblazed's Avatar
Get'em Started Early
VSS maybe
Old Nov 17, 2009 | 10:51 AM
  #17 (permalink)
civic_loner22's Avatar
ek9 mofucka
Originally Posted by Arcangelff7
codes ????
the ecu throw out codes wen u put your key into the on position (dnt turn on engine just put in the on position)
before that move the rug bak from where the ecu is (passenger feet)
u can take the big metal plate covering it off but personally i leave it on
then put the key into the on positon and mark how many time the ecu throw out light ... its gonna throw out lets say 13 then there gonna b a longer pause then u count again if its 13 again u got a 13 issue (this would b a god time to have a manuel booketl from your local auto shop autozone advance auto etc.. in this manuel it will tell u what all the code mean or jus go online look for online manuel )
Old Nov 25, 2009 | 02:54 PM
  #18 (permalink)
ill be cheking on that thanks !
Old Nov 25, 2009 | 11:13 PM
  #19 (permalink)
00vtecsi's Avatar
slow ass car
map and tps backwards? check iacv wires... should be center wire on Map green, on Tps red, and Iacv should be yellow w/black, and black w/blue, if its red instead, find the right one. LMK if it helps
HELP:https://www.tamparacing.com/forums/h...er-fender.html
-Tuned Performance-/---------------------------------CentralForidaAutowerks ----->660sw 13th st. ocala<------JJC autoworks--shop forum
tuning,turbo installs,custom wiring tucks, nitrous systems, engine swaps,ecu's,engine building,much more, some of the cleanest, most affordable work around 352-857-2715 jason....
Old Nov 26, 2009 | 05:42 AM
  #20 (permalink)
chi town brat's Avatar
! Ne shab'rud'ni !
Moved to the correct forum for tech assistance.
chi town brat
S Mod
