Wondering why?
Old Oct 29, 2009 | 12:38 PM
HoTsAuCe91's Avatar
Help me please dang man
EG Crew Member #23
Old Oct 29, 2009 | 02:01 PM
YARO's Avatar
Smith & Wesson Protected.
on the thermostat housing. If you jump the plug the fan should turn on.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Oct 29, 2009 | 02:18 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Well if your fan doesn't turn on at idle, and the temp keeps going up past where it's supposed to be, then I think you figured out your problem.
-Winston Churchill
Old Oct 29, 2009 | 03:56 PM
HoTsAuCe91's Avatar
How u jump the plug off the thermostat?
EG Crew Member #23
Old Oct 30, 2009 | 09:54 PM
HoTsAuCe91's Avatar
Ttt need help still
EG Crew Member #23
Old Nov 1, 2009 | 02:52 PM
AllShowNoGo's Avatar
you unplug the fan switch and put a jumper wire in it and cover it with tape, This will make the fan come on when you turn on the ignition
Old Nov 1, 2009 | 06:12 PM
  #17 (permalink)
01LatinVizionGSR's Avatar
you jump the plug by disconnecting the plug for the fan switch witch is on the thermostat housing by inserting a wire from one side of the connector to the other. Just like if your were jumping the diagnostic port. I guarantee you your fan is not coming on thats why it only overheats in idle and not when your driving. and if the car takes long to turn on when its hot is probably the ignition coil its probably getting to hot. Usually when it does this its because oil is getting inside the dizzy or your valve cover is leaking oil like crazy into your spark plugs. Hope this helps.
Old Nov 2, 2009 | 06:47 AM
  #18 (permalink)
HoTsAuCe91's Avatar
Thanks i will check it out thanks a lot
EG Crew Member #23
Old Nov 2, 2009 | 07:05 AM
  #19 (permalink)
BoostedRacerDad's Avatar
Pops
I think you need this from Autozone
by Price: High Low --- Select a Brand --- Duralast Everco Santech
Duralast / Cooling Fan Switch - Radiator Part Number:
TU197
</IMG>
Price:
$22.99
Notes:
Located in thermostat housing
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Nov 2, 2009 | 08:22 AM
  #20 (permalink)
HoTsAuCe91's Avatar
Yea that piece rounding is broken thats why the plug is always disconnected
EG Crew Member #23
