starting issues with the DC!
Old Oct 26, 2009 | 07:27 PM
JDMrockstar7's Avatar
Default starting issues with the DC!
hey I have a question about my 96 integra, it wouldnt start one day i tried and tried it would keep turning over but wouldt actually start, then the next day I tried it and it started right up. ever sence then its taking longer and longer each day to actually start up, what is it? starter maybe? dizzy?i dont smell any gas so it shouldnt be anything to do with fuel right? lmk thanks
Old Oct 26, 2009 | 07:31 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
check your fuel pressure. take a 17mm to the return fuel line running from the rail to the filter and loosen it. then have a friend turn the key to ACC and fuel should shoot out everywhere if you have pressure. just make sure you do it quick! also listen for a humming sound coming from right under your driver side door, it'll only be on for a few seconds.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Oct 26, 2009 | 07:33 PM
CRAWFORD BUILT
if the rotating assembly is turning over fine then your starter is good.
CRAWFORD BUILT
DC Crew Member #23
Old Oct 26, 2009 | 08:00 PM
alright thanks for the advice bro Rep'd! ill check it out in the a.m. and get back to you, do you have a number i could reach you at if i need help tomarrow?
Old Oct 26, 2009 | 08:26 PM
CRAWFORD BUILT
yeah man 352-215-0892 and rep returned!
CRAWFORD BUILT
DC Crew Member #23
Old Oct 29, 2009 | 08:57 AM
HoTsAuCe91's Avatar
I think my eg hatch has the same problem
EG Crew Member #23
