wats a good compresion on a b16
Bad? Something in your motor is fucked. That 150 is disasterous. The 180 is pretty fucking bad too, and I wouldn't be happy about that 200 either.
BTW, it depends on whats done to the motor, but 230s for stock with ~10:1 compression would be pretty normal.
"They were crying when their sons left, God is wearing black. Hes gone so far to find no hope, hes never coming back. They were crying when their sons left, all young men must go. Hes come so far to find the truth hes never going home."
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
If you measured properly and you have 200 in one cylinder and 150 in another cylinder, your car may not be smoking but it is certianly not running good.
Give us a little background on the motor. How many miles on it? Nitrous, turbo, anything? What kind of compression is it running? What kind of head gasket do you have and how old is it? Have you checked to make sure you don't have a blown headgasket anywhere? Who built the motor, are you sure the rings ever seated properly to begin with? How many miles on your heads? What kind of parts are in your valve train? What kind of rings do you have in it?
You're leaking compression. Its leaking from your rings, bad seal on the valves in your head, or your headgasket.
Make sure your battery is fully charged too while your doing these tests...if the battery begins to loose power it will turn back lower readings. Redo the tests and start with that low cylinder first and make sure you do the same routine when testing each cylinder. If tests come back that same as before drop a tablespoon of oil into that low cylinder and retest that one cylinder. If compression increases quite a bit then your rings are worn out, if it stays the same you probably have a problem in the head like a bent valve or something.
I dont like how low the 3rd #..
My B18c was 10.6:1 around 250+ across the board.
I took info below from phearable.net, Im not sure how accurate it is but should give you an Idea of what you should be around.
* Engine compression (No more then 20psi between cylinders.)
8:1-8.5:1 c/r = 150-170 psi per cylinder
8.5:1-9.5:1 c/r = 170-210 psi per cylinder
9.5:1-11:1 c/r = 210-275 psi per cylinder
11:1+ c/r = 250+ per cylinder
^ those numbers are pretty accurate. My LS motor cranked out 185ish across the board and thats a 9.1:1 motor...the gsr I tested cranked out 230ish across the board.
