B18 turbo mani and downpipe.. need advice!!!
my wastegate is the 38mm tial and its 5 inchs tall.. i couldnt find the seller or any of the manifolds! i've never had so much trouble finding a part before lol its either ridiculously expensive or crap!
00 Integra LS/Turbo - Traded
06 GSX-R 750 - Sold
08 Daytona 675 - My Toy
12 Si Sedan - DD
06 GSX-R 750 - Sold
12 Si Sedan - DD
I'm not sure if a 5" tall would clear...I'd have to clay the top of my wastegate and see hood clearance. Another choice in manifolds is blox. The runners are a little smaller in diameter than my meutek ones are but the wastegate placement is still good.
damn, now i'm thinking about a log manifold after reading this ^^^ and no i haven't bought it yet, i'm still doing suspension work right now.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
The meutek manifold is awesome and I heard that inlinepro's manifold is good too but inlinepro is like $500 for a log manifold. The meutek is cast and probably doesn't flow as well as a ramhorn up top but for most street and some semibuilt applications it will work great. I've seen people that have hit 500whp using the meutek manifold.
i went with the block log with the wastegate located on the 2 and 3 runner... thanks
06 GSX-R 750 - Sold
12 Si Sedan - DD
06 GSX-R 750 - Sold
12 Si Sedan - DD
lovefab and SFP SS manifolds, you don't really NEED to go ram horn style, LOG mani's work just fine... LHT does great exhaust/DP work but $$$, I'd just find a manifold/downpipe/turbo setup on the board, you can find some good deals, just make sure its a/c compatible and SS.
Inline Pro makes hands down the best cast manifold, and probably the best log style manifold on the market... It is made from cast stainless steel, unlike others that are made from cast iron, this is far superior for many reasons... they are also a far superior design, and flow much better than any others... I have personally seen cars at and above 700whp with the inline pro manifolds... do your research and spend the money the first time, instead of having to do it twice...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
