94 accord brake hydraulics query
Old Oct 17, 2009 | 11:11 AM
jim's Avatar
jim
Default 94 accord brake hydraulics query
It's a 94 accord ex with abs, with mushy weak brakes, pedal to the floor to stop. Only 2 disks, one front and one rear, are warm, after a spin around the block. If the problrm is the master cylinder, is the front chamber for left front and right rear, or is it the other way? Could the abs cause these symptoms?
Thanks.
Old Oct 19, 2009 | 04:15 PM
Prelude_!n_7h3_D!r7's Avatar
did you open up the break fluid cap recently?
"How fast is Fast enough"
Old Oct 19, 2009 | 05:59 PM
Nandosol's Avatar
Garage Slut
bleed them, check for leaks
What do you mean you have two disk brakes one in the front one in the back?
Old Oct 23, 2009 | 06:18 PM
jim's Avatar
jim
Two disks are warm, two are not. The fluid used to slowly leak with use of the car, but not lately since it's been sitting.
Old Oct 23, 2009 | 07:43 PM
Nandosol's Avatar
Garage Slut
If theres leaks there is air = Crappy pedal feel(and actual stopping)
Leaks dont magically fix themselves. Unless you have elves living in your garage.
Old Oct 26, 2009 | 08:43 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
^^^ send those elves my way!
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Apr 7, 2010 | 08:05 PM
jim's Avatar
jim
My neighbor says the master cylinder sections are for front and back brakes, not diagonally, like I surmised. Now I'm confused even more.
Old Apr 14, 2010 | 01:16 AM
Default Brake cylinder solutions
Some master cyls have the front chamber for front brakes and the rear chamber for rear brakes. That way if you have a line leak, you still have "some" brakes left to get you home...
The brakes that are cold are not working to stop, or you would feel some heat. On the front of the car replace both wheel cylinders/calipers for equal braking, and bleed the air out.....it will show a big difference.
Then do the same for the back brakes.
If you need some help, get back with me. -Bob
