Heres one for you??? im stumped
Old Oct 15, 2009 | 08:04 AM
AUDIcabrio09's Avatar
Exclamation Heres one for you??? im stumped
ok so i boosted my ef...the problem is that it wont start unless i am giving it gas...i had the tuner come over and see if he can tune it thinking maybe that was the problem...he hooked up his computer and it said my MAP was reading 10lbs just at idle...which was then dumping hella fuel into the cyclenders with not enough air causing it to die...
Why is my map doing this?
i got 3 cel codes...8,10,14...air intake temp...TDC sensor?..and something else...
what should i do...has anyone ever had this problem..if you need anymore infor lmk.im bad at threads lol
Old Oct 15, 2009 | 08:10 AM
BABILLARACING's Avatar
what map sensor you have? stock ......., how much boost?
My shit still slow
618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
stock block ,more power coming soon ,stay tuned
Tuned by Alpha @ Induction Performance
Old Oct 15, 2009 | 08:11 AM
stock map sensor..i havent even tuned the car because we cant get it to idle...i have a walbro255 and dsm 450s with a basemap...the motor is a stock ls..
Old Oct 15, 2009 | 09:09 AM
custom240sx's Avatar
DC Crew Member #1
Throw in another map sensor...sounds like it may be screwed up sending the wrong resistance to the computer
Old Oct 15, 2009 | 09:22 AM
im gonna try that tonight and see what happens..if not anyother ideas.
Old Oct 15, 2009 | 09:28 AM
would the TDC sensor have anything to do with it..
Old Oct 15, 2009 | 11:23 AM
Alpha's Avatar
Put another map sensor in the car. That should solve the issue. If not, check the voltage in, voltage out and that the sensor ground is good. 14 is idle air control valve. Try another distributor for code 8. If that doesn't work go over the wiring
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Oct 15, 2009 | 12:17 PM
Spartan UT's Avatar
Bowley
is the timing off? cause i had a car that was idling bad cause the timing was bad
My Sexy Car Her name is Isis "Greek for The Throne"
Robert better not get in my face... 'cause I'll drop that motherfucker!
You're a big, fat, curly-headed fuck!
Suppose Nancy sees me coming out of the shower and decides to come on to me. I'm looking good, got a luscious v of hair going through my chest pubes down to my ball fro. She takes one look at me and goes " Oh my god, I've had the old bull now I want the young calf" and grabs me by the weiner.
Old Oct 16, 2009 | 07:33 PM
i changed the map sensor and still the same????
Old Oct 17, 2009 | 02:24 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
^check the wiring.
Maybe someone ghetto rigged the harness somehow, you never know these days.
-Winston Churchill
