95 integra ls no spark
Old Oct 9, 2009 | 05:57 PM
Bigfly180's Avatar
Default 95 integra ls no spark
I noticed a wires arking on the valve cover and when i toched it the car just shut off, went to start it and nothing first thing i did is i checked for spark and nothing could that short out the crack sensor or dist.?
1993 hatch-Building
1998 Z71
2004 GSX-R 1000
Old Oct 10, 2009 | 08:55 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
that wire is your engine block ground wire, tighten it down and where it's attached to the frame/body make sure you have a good connection. you won't get spark from the ignition coil unless it's grounded correctly.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Oct 11, 2009 | 10:17 AM
Bigfly180's Avatar
ok checked that, when it happend it was running, seen it arking barly tuched the wire and it just stopped running
1993 hatch-Building
1998 Z71
2004 GSX-R 1000
Old Oct 11, 2009 | 10:48 AM
CRAWFORD BUILT
oh you might have blown the coil when you did that.
CRAWFORD BUILT
DC Crew Member #23
Old Oct 11, 2009 | 12:08 PM
Bigfly180's Avatar
yea thats what im thinking ill find out tomarrow if it fixes it ill post it up
1993 hatch-Building
1998 Z71
2004 GSX-R 1000
