wiring problem: altanator, and head light, and almost a fire
Old Oct 7, 2009 | 04:13 PM
luvsracin87's Avatar
turbo hhhmmmm?
Default wiring problem: altanator, and head light, and almost a fire
Ok TR I'm stumped on this 1 and I need help I have a 95 EG hatch with a LS swap
I was driving home yesterday and I smelt wires burning, I pull in to my drive way and pop my hood(with motor running) to see my fuse box smoking were the altenator wire screws in.
I took the altenator off and took it to advance auto to get it tested and they told me it had a bad dieode. Ok so I had a extra altenator layin around I put it, and I replace the fuse box.
I start the car with the altenator wire not hooked up, when I try to hook it up it arcs and makes the lights dim and seems to put a massive load on the car. The battery light is on and when I turn the lights on the battery light turns off,and the wire still arcs, I even tried another wire from the altenator to the fuse box and still the same thing
As I look around the engine bay the passenger side light plug looks like it got hot and grounded out. I don't know how this things are connected. I'm stumped any suggestions will help I'm out of ideas
Steve: (813) 810.4146 <~ call or text
Old Oct 7, 2009 | 07:56 PM
turbo hhhmmmm?
Any1?
Old Oct 7, 2009 | 08:02 PM
lzylst's Avatar
Do you have any grounds? at least the trans side and valve cover. I usually add a third one from the drivers shock tower to valve cover.
If you have them... the high output blue headlights lights, throw them away. I would be very cautious of the HID setups also. Especially if you are not running a relay and are using factory wiring.
Vance @ 863-604-2139 for any questions
Old Oct 8, 2009 | 02:31 AM
turbo hhhmmmm?
Yeah I have grounds. And I'm running hid's
Old Oct 8, 2009 | 05:00 AM
turbo hhhmmmm?
Old Oct 8, 2009 | 03:19 PM
turbo hhhmmmm?
Fixed it! I got another alternator and put my voltage regulater on it and that fixed evry thing
