High Compression ?
Old Mar 28, 2002 | 12:14 PM
  #21 (permalink)
Bill's Avatar
Livin' in Seattle
Originally posted by "Someone"
Originally posted by Robster
so why did endyn make hte rollerwave as smooth as they did? What causes detonation a lean condition and a hot spot. If what you say is true then why doesnt everybody run 13:1 and 14:1 compression when all you would need would be a much colder plug and fuel??? So what is hte purpose of polishing the combustion chambers on high hp/race motors?
Endyne didnt make them smooth like I said above they simply radiused the edges around the valve recesses and roughed up the surface of the dome a bit. This was all in an effort to reduce hot spotting yes but these are HUGE edges we are talking about when compared to the bowl surface.
Also I think youve got detonation mixed up. Youre thinking of pre-ignition which is caused by the mixture being set of by something other than the plug.
But back to the argument what do you mean by what you say is true then why doesnt everybody run 13:1 and 14:1 compression?
I havent said anything about people running high compression ratios or that people ONLY need a colder plug and higher octane fuel this whole debate started when you said that in order to combat detonation you need to smooth the bowls. Sure itll help but but like I initially said it is much more beneficial to SHAPE the bowls since the bowls arent in such HORRIBLE shape as to cause hotspotting. Detonation is an uncontrolled burning of the mixture resulting from end gases in the mixture igniting before the flame front has a chance to. This can be minimized by changing the combustion chamber shape and piston floors to promote a complete burn and one that occurs quickly enough not to allow end gas ignition.
I think youve lost track with all this back and forth of what this argument was originally about.
Old Mar 28, 2002 | 12:16 PM
  #22 (permalink)
Bill's Avatar
Livin' in Seattle
Originally Posted by Someone
Originally posted by Boosted Z31
who in the hell cares
build your motor to handle it.
because were having a friendly mature discussion about detonation and combustion chamber design whats wrong with that?
Yup forgive us if were not were not just sitting back asking which motor will fit in which chassis etc.
Old Mar 28, 2002 | 12:47 PM
  #23 (permalink)
night rider's Avatar
since I am not going all out race and this is a daily driven car that must last me throughout college if I use a compression ratio of some where between 11.3 and 11.5:1 just to be safe would I need a forged piston or could I get away with a factory cast one?
Old Mar 28, 2002 | 01:34 PM
  #24 (permalink)
KJ's Avatar
KJ
bored at work
factory cast piston would work nicely. JDM itr pistons would come really close to 11.5:1. I dont have a calculator around so I cant give you a definite #.
Old Mar 28, 2002 | 08:40 PM
  #26 (permalink)
GOTTI's Avatar
OEM Parts Specialist
so do you guys think 12.5:1 is too high for a sohc with Honda parts?? i heard it will run fine...
Old Mar 29, 2002 | 08:53 AM
  #27 (permalink)
quicksilver EK's Avatar
The one punch machine gun
Two words.....NO FAKEDYN
97 ITR-Mugen Equiped
04 Honda 600RR
Old Mar 29, 2002 | 09:10 AM
  #28 (permalink)
Matt Vassallo's Avatar
lifelong learner
so you have first hand experience dealing with what compression works on these hondas?
sit down
rest in peace tim.
Old Mar 29, 2002 | 01:37 PM
  #29 (permalink)
Bill's Avatar
Livin' in Seattle
sit down
What in the world does that have to do with debating engine theory? As for my views Ive fixed enough seen enough and read enough to have a good idea of what Im talking about.
Stand up??
Old Mar 29, 2002 | 01:56 PM
  #30 (permalink)
Bill's Avatar
Livin' in Seattle
loooooong story which basically boils down to Larry telling a lot of lies and now having lost a lot of the following he used to have.
