Plz Help Verry Wierd Problem
Old Oct 5, 2009 | 02:38 PM
dshane's Avatar
Default Plz Help Verry Wierd Problem
ok my 94 ls is bone stock, with ice cold ac. heres the kicker when i run the ac my car wont start like the batteries dead. when i dont use the ac its fine. has any one ever herd of this or any suggestions?
Old Oct 5, 2009 | 03:07 PM
rangcrx's Avatar
engine building &best
buy a Higher CCa battery
i love AUTOZONE
Old Oct 6, 2009 | 12:47 AM
CheesePhantom's Avatar
Are YOU in the ACT?
I don't understand...
You turn on the A/C before you start the car?
Or do you mean that through repeated use of your A/C, your battery loses its charge? How do you get it to start whenever the battery "dies?"
Bold Performance
Old Oct 6, 2009 | 04:03 AM
dshane's Avatar
In general if i use the ac the car will not start if i turn it off and turn it on again. i eather push start it or jump it
Old Oct 6, 2009 | 04:41 AM
rangcrx's Avatar
Either your battery is bad.or your alt is not chargeing to the correct voltage
i love AUTOZONE
Old Oct 6, 2009 | 08:56 AM
dshane's Avatar
ok thanks
Old Oct 6, 2009 | 12:28 PM
Are YOU in the ACT?
+1
Take your battery to Autozone/AAP/Pepboys to get it tested.
Testing your alternator is a little tricky. You can either take it out and get it tested at those same auto shops, or you can start the car, wait thirty seconds and then unplug the battery from the car. If the car shuts off, the alternator is bad. Useful little trick. Definitely saves time.
Bold Performance
Old Oct 8, 2009 | 12:32 AM
dshane's Avatar
what do you mean by "unpluging" the battery from the car?
Old Oct 8, 2009 | 12:34 AM
SuburbanNoize's Avatar
Cold Ass Honky
Removing the cables from the battery.
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old Oct 8, 2009 | 12:50 AM
dshane's Avatar
ok just disconecting then
