need a little advise on my turbo setup
Old Oct 3, 2009 | 01:52 PM
whiplash129292's Avatar
Default need a little advise on my turbo setup
i have a jdm d15 vtec
currently im running 4 psi off the wastegate, with a p08 ecu, stock injectors
I am wondering if i was fine to drive it like it is for a week, the map sensor isnt reading the boost so if i get on it a little bit it goes into safe mode.
i appreciate it guys for advise
let me know if you need more information than that, thanks
Old Oct 3, 2009 | 02:11 PM
custom240sx's Avatar
DC Crew Member #1
Just don't let it go into boost at all...drive very easy and you should be fine. Get it tuned with the right injectors though ASAP
Old Oct 3, 2009 | 03:42 PM
yea i have injectors and fuel rail just didnt put it on because im only running 4 psi and on stock ecu, so im not dumping useless fuel into it.
as for a tune do i need to get a dyno tune? wheres the best place to go?
Old Oct 3, 2009 | 04:58 PM
DC Crew Member #1
Street tune or dyno tune...contact mtber or jap or alpha on here...all do good jobs of tuning and can get you all set up.
Old Oct 8, 2009 | 07:05 AM
MightyMaxGS-T's Avatar
you need some injectors sir, i have a set of prelude 310cc if you need them, i would go bigger tho.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Oct 8, 2009 | 03:16 PM
DC Crew Member #1
If your talking peak and hold prelude injectors they are 345cc and they worked fine on my b20b boosted to 7psi
Old Oct 8, 2009 | 03:50 PM
i have dsm 450cc injectors, not putting them on until i get a tune
