tranmisson
Guest
Posts: n/a
input shaft bearings go bad from fluid not being changed often enough and also too many hard downshifts which also happens to be the main cause for a bad shift fork. A new shift linkage wont have any benifit to your gear set unless of course your shift linkages are bent fairly bad where each gear is a grind regardless of engine rpm.
