acura started problem. NEED HELP
Ok so im having problems with my car turning over just because for some reason my starter doesnt get power unless i run it direct to my battery. so yea it sucks i always need to push start my car or run it direct to start it. and im not sure wat the problem is.. everythings connected perectly right on my starter i even bought a new one to see if it was dat and it wasnt, some one please help and lmk wat is up with this. also nun of my fuses are blown. in addition to all this. when i got my swap my car had 2 battery setup wires for some reason
i also have a problem with my car over heating.. if it sits for to long without running all the fluid run into my radiator and it over heats.. i was wondering if it was the water pump or wat
started relay is in the fusebox of my enginebay right? if it is i would double check it. but someone was tellin me i have a problem with my ignition and dat i would have to run a switch
