need phone number of a guru kinda stumped and need help
Old Sep 28, 2009 | 10:28 AM
customkid72's Avatar
Default need phone number of a guru kinda stumped and need help
ok i have a ls block that had type r pistons and it do called had bad rings but i need info to c how to check it only thing i did is while it was still together i poored oil in to see if it pored threw it it sept threw in about two days so im not sure?
so if someone can give me a number to help me out it would be great?
seffner meet getting started so click here to get inhttps://www.tamparacing.com/forums/local-events/745189-seffne-meet-lets-get-something-started.html
*ad removed*contact admin@tamparacing.com to ADVERTISE on here....
Old Sep 28, 2009 | 10:39 AM
JoKiE crx4294's Avatar
popeye built!
there will always be some blow-by in engines. it does not seal 100%.
Can't spell strength without tren
AAS...It's whats for dinner
Old Sep 28, 2009 | 10:59 AM
custom240sx's Avatar
DC Crew Member #1
Is the motor in the car still? If so it needs a compression test.
Old Sep 28, 2009 | 11:43 AM
onebadcoupe's Avatar
lol cleveland u already know im a honda/engine encyclopeida.unless the engine in still in the car and fully assembled you cant do a compression test. car has to be warmed up to get accurate results . but oil will always pass by rings if you simply pour it into the cylinder. think about when you do a "wet" compression test and the number shoot up. thats because oil is passing by the rings and providing a better seal. so thats not a way to indicate if rings are good or bad.
94 dohc vtec ej1 FS
https://www.tamparacing.com/forums/c...ml#post7081439
Old Sep 28, 2009 | 11:59 AM
well the thing is that the block supposedly needed rings so we bought the car it have a mis fire and the guy said it was because the ring in number 3 was gone but i dont think they are i took it apart and the number 2 piston was still shinney as hell like new
but the car drove fine besides the mis fire
Old Sep 28, 2009 | 12:30 PM
rangcrx's Avatar
engine building &best
the one thing i try to say is,if you think or have a doubt then replace it,rings are only about 30bucks so repllace them..its better then putting it all back together then having to take it apart
i love AUTOZONE
Old Sep 28, 2009 | 01:53 PM
a misfire is ignition related. if the 1 cylinder wasnt even firing it cant be the cylinder that was misfiring. in my opinion. you cant really trust people's word now a days its a shame. i would re-ring the entire motor, fresh hone and bearings. than you'll know for a fact what you have.
94 dohc vtec ej1 FS
Old Sep 28, 2009 | 02:51 PM
thats what i thought but then i change the injectors and notice one was stuck closed
Old Sep 28, 2009 | 03:39 PM
BABILLARACING's Avatar
misfire could be a lot of things , low compresion due to worn out rings ,bend valves, valves not seating properly (burn valves) also bad injector ,no pulsation ,bad spark plug or wire .it could be a lot of things..........hope this help ...Omar
My shit still slow
618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
stock block ,more power coming soon ,stay tuned
Tuned by Alpha @ Induction Performance
Old Sep 28, 2009 | 05:41 PM
thanks alot bro
