b16a rod bearing specifications
i think he means the tolerance range. im not going to tell you because theres plenty of info on the net and if you're building a motor you should have a factory service manual with you.
or go to the machine shop, standardize the crank and run acl race bearings.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
i love AUTOZONE
i love AUTOZONE
i like my cranks how they came from honda. no need removing material if its not nessecary. just get a inside & outside micrometer set, dial bore guage telescoping bore guages if youre cheap lol. add the inside and outside measurements and multiply that by bearing thicknesses from the honda bearing chart to find your proper clearances. .0015 is right in the middle of the spec. remember plastiguage is your friend.
^PLUS the crank will be back to a polished glass surface like it was when first installed less chance of problems
i love AUTOZONE
i love AUTOZONE
^always got my back lol....rang and i build A LOT of motors, standardizing a crank on a honda is standard practice on a rebuild. it won't cause reliability issues, you will be fine. if ur worried about it buy an eagle crank.
