The Spectacle is back - Turbo AP1 420whp/250tq @ 14psi
Life threw a few curveballs at me so I had to lay low for a while. But, I'm back
Did you miss me?
2001 Honda S2000 77k miles
Stock motor
1000cc injectors
Walbro 255 fuel pump
Precision 5857 turbo
2.5 inch downpipe to 3 in catless and no resonator exhaust piping
80mm Apexi N1 Turbo muffler
Precision 600hp intercooler
Tial Wategate (recirculated back into exhaust)
Tial Blow off valve
4 bar Map
EBC boost controller with boost by gear
Hondata Kpro
PLX wideband
420whp/250wtq on a dyno dynamics. Ignore the spool to RPM correlation, the DD is setup a little weird so it looks like it spools hella late. Definitely not the case.
Dyno Video:
YouTube - Mase Engineering S2000 Turbo Kit Dyno Video
More details and pics here: http://www.s2ki.com/forums/index.php?showtopic=732015
Car runs pretty good. mtber or Alpha, if you see this please PM me.
Did you miss me?2001 Honda S2000 77k miles
Stock motor
1000cc injectors
Tial Blow off valve
4 bar Map
Hondata Kpro
PLX wideband
Dyno Video:
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
Read my post again.
Racing Integration
LHT Performance
Racing Integration
LHT Performance
Dunno. Its turned down to ~ 11-12 psi for the street. And even then, I don't know when I hit full boost yet. I'll do some datalogging today and post up.
Racing Integration
LHT Performance
Racing Integration
LHT Performance
Good numbers. Should run real good.
-Induction Performance
ALPHA Tuned.
-ROQUE MACHINE SHOP
For ALL your fabrication needs.
-ROQUE MACHINE SHOP
Racing Integration
LHT Performance
Racing Integration
LHT Performance
They're good for about 450whp on pump gas. A lot of guys add a 3mm headgasket to run more boost and take it above 500whp...something I will NOT be doing.
Racing Integration
LHT Performance
Racing Integration
LHT Performance
