A/C Question
Old Sep 15, 2009 | 12:06 PM
vt_sol_ec's Avatar
I Give My .02 When Needed
Default A/C Question
Hey TR, I need some help on my A/C problem in my 94' Del Sol. I just replaced the high pressure line and checked for leaks, which i've found none of. The problem is, is the 2 vents on the passenger side are blowing out super cold, but the other 2 on the driver side are not near as cold. I was told that my thermostat was on the passenger side so that's why those 2 are blowing colder than the other 2. We put 2 cans of freon when we fixed the line, so I was wondering if it just needs another can of freon or if there is another issue. ANY HELP WOULD BE AWESOME! Rep will be given for any help!!
Nikon Owner
IG: @equippedphotography
FB: Equipped Photography
1994 Integra RS - Stock LS/SOLD
1994 Del Sol - Stock D16y8/TRADED
1990 CRX Si - SiR B16a/TRADED
1998 Integra GS - JDM B20b/TRADED
1994 Integra GSR - Tuned H22a/TRADED
1999 EK Coupe - Backburner
1995 JDM Front Integra - Project
2014 F-150 5.0L - DD
Old Sep 18, 2009 | 06:59 AM
Under the dash.......Are all ducts lined up, plugged in, and in place with plastic sleeves in place?
Is there a slide control lever accessable to the driver,that will open the ducts on each side of the car?-Bob
Old Sep 18, 2009 | 11:51 AM
vt_sol_ec's Avatar
^i didnt see a slide control lever. where would it be located at? thanks for the help bro.
Nikon Owner
Old Sep 18, 2009 | 11:58 PM
rangcrx's Avatar
engine building &best
all 3 vents come from the same duct and blower.the only reason the passanges would be "cooler" would be its passing close to the Evap box
i love AUTOZONE
Old Sep 19, 2009 | 07:08 AM
vt_sol_ec's Avatar
^ya thats what i was told. so do i just take my glove box out and check the ducts?
Nikon Owner
Old Sep 19, 2009 | 08:35 PM
Your car may be different. Mine are within 8" to the right of the key,
under the dash. Closing off the pass side sends more air to the driver side.
If I cool the driver, the cabin will take care of itself. I also plugged the duct under the carpet on the pass side, and extended the d-side duct almost to the steering wheel.-Bob
Taking the glove box down is easy and a start.....you might also need a flashlight.....-Bob
Old Sep 20, 2009 | 08:46 AM
vt_sol_ec's Avatar
^ok when i get a chance i will take my dash apart and check it out.
Nikon Owner
Old Sep 26, 2009 | 08:52 AM
vt_sol_ec's Avatar
well my drain tube isnt clogged and i just put in a 3rd can of freon and it purged all the excess out of the bottom of the compresser. now it will blow cold for about 3mins then will blow hot and my idle will be fucked up. when i stop the idle will fluctuate between 900 - 1200 rpm's. then it will stop and blow cold again. i dont know what the fuck is going on, but im tired of throwing money at this stupid shit.
Nikon Owner
Old Sep 26, 2009 | 12:22 PM
MightyMaxGS-T's Avatar
bring it by...i'll tell you whats wrong lol unless ur really in gainesville, then i'm just joking...you need to have someone with an ac manifold hook the gauges up to ur car and see what is going on with the high side and low side simultaneously.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Sep 26, 2009 | 12:42 PM
vt_sol_ec's Avatar
^im really located in gainesville. i have a guy who has the guages and everything but i havent had time to take it by him yet. 2 weeks ago i took it to him and we replaced the high pressure line and put 2 cans of freon in it and it blew out cold. then it just started blowing sorta cold for the rest of the week. this morning i put a 3rd can in and it purged some out of the compresser and is messing with my idle. how many cans are supposed to go in? the motor is a D16y8, if that helps any.
Nikon Owner
