quick question
quick question
wenever i make a hard right turn my car makes a knocking noise. the faser im turning the worse it is. this would be the cv halfshaft right? or wat could it be?
cv joint maybe?
youre going to have to look at it
Jack up the front end and look at the boot. See ifs torn.
Also while its jacked up see if you can move the wheel up or down, side to side. You could have other suspension issues.
check the wheel bearin... alxe or even the axle nut came loose and is layin in the hub of the rim so when u take the wheel off the nut falls out lol..that happened to my boy not to long ago n thats why his car was doin what urs is
I hope your boy doesnt work at a shop , axle nuts dont come loose if they were ever tightened
if it sounds like a clak clak clak clak then its the outer joints in your cv shaft that is bad.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
