car shuts off when i turn it on..
Old Sep 13, 2009 | 07:28 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
hmm... i used to have that problem with a DA9 i had, i just turned up the idle speed and unhooked the IACV.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Sep 13, 2009 | 04:44 PM
crexneffex's Avatar
Is never scared
could be gas cycling back to the tank, before you turn it over to start it turn the key and listen for the fuel pump it should be a slight hum, could be the pump going and not pushing like it should, try priming it 2-3 times before actually tryna start it
Single Cam:The best way to get some sleep
Single Cam:My anti-theft device
Old Sep 13, 2009 | 05:10 PM
Santos's Avatar
also, it could possibly be an ignition switch going out. happened to me, then eventually i had to drive the car home holding the key in the on position lol.
TR "Old Skool" DA member #60
Santos618 - Xbox 360 gamertag
GTA4
Forza 4
Madden 12
open to any good online games, i just suck at shooters lol
Old Sep 13, 2009 | 07:50 PM
lopezchris21's Avatar
its just when i start the car when its cold. thats all. if i run into a store and come out and start it it starts perfectly fine.... i got a wal 255 pump also...
TR 5th Gen Civic CREW Member # 04
Old Sep 13, 2009 | 08:55 PM
FrodoGT's Avatar
Found the Vtec switch.
Sounds like your iacv isnt working properly. What rpm do you idle at when warm/cold (if at all). On all 92-up cars the idle is solely controlled by the iacv, assuming that the throttle isnt open too far for it to actually make a difference.
TR Old Skool EF Crew #24
Old Sep 13, 2009 | 10:43 PM
crexneffex's Avatar
Is never scared
had the same problem on my turbo'd hatch with a walbro 255 never figured out what it was.. so i just went with the "priming" as said before problem solved
