Soon to build 1.8 need some help
Id like to start building a 1.8 block within the next couple months need a few ? asked first I know CTR pistons dont work with B16a rods but I need to know will ITR or CTR pistons work with B18c1 rods? is there any differance between ITR rods and B18c1 rods? also does anyone know where I can get the a crank balanced? or a machine shop to inspect the block of cracks
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
14.729 @ 94.79
yes you can use the itr or ctr pistons with your b18c rods. i would use the itr though because if you use the ctr you compression will be way to high for a daily car. the itr rods and gsr rods are the same
2013 Volkswagen CC, yes that is my new ride
Thanx Id like to build it in the 11.5:1 - 12:1 area
14.729 @ 94.79
14.729 @ 94.79
it wouldnt go any higher than 11.5:1 what kinda of head do you plan on using? if you use a gsr head go with usdm integra type r pistons it will give you about a 11.3:1 if you use a b16 head use some jdm integra type r pistons which will give you about a 11.5:1 ratio
Guest
Posts: n/a
well if a true bad ass use the pct (ctr) pistons an a gsr head hahah no on a seriuos note i would go with a gsr or ls block an put a type r head on it an use jdm type r pistons call it a day !
97 ITR-Mugen Equiped
04 Honda 600RR
04 Honda 600RR
You can get the bottom end balanced at Dwans(pinellas) or Eiseleys(Tampa). For balancing Eiseleys prices was a little more $140 vs $125 (crank rods pistons balanced) but the other prices were a little cheaper. I liked their service.
Im goiong to be using a B16a head with spoon 2ply gasket
14.729 @ 94.79
14.729 @ 94.79
Guest
Posts: n/a
USDM ITR pistons with gsr head is 10.8:1
JDM ITR pistons with B16 head is roughly 11.1:1
With the Spoon gasket and b16 head using JDM ITR pistons would yeild about 11.3:1
With B16 pistons you would have your 11.5:1 cr....
i dont think so look at what this site has to say about the compresion ratios
http://www.bojangz.com/calculator/
id say i was pretty right
