Over heating @ Idle
Old Mar 17, 2002 | 08:26 AM
88EFSiR1J1's Avatar
When my car is stationary but running for about 5 min. the heat gauge peaks and I notice that my radiator fan doesnt come on. once I get moving the guage goes back down is there any way of knowing whether this is due to the thermalswitch or of the fan? it seems to have stop working after I pulled out my A/C do I need to bypass something after taking out the compressor for my radiator fan to run?
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
Old Mar 17, 2002 | 08:47 AM
letsrollagn's Avatar
BRT OVERKILL
yeah take the two wires to the fan and put one on ground an the other to an accessory or battery and if the fan does not come on its the fan motor or wiring and if it works its the thermo switch.
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
Old Mar 17, 2002 | 12:07 PM
88EFSiR1J1's Avatar
thanx thats nice and all but what do i do? cut the wires?
14.729 @ 94.79
Old Mar 17, 2002 | 02:05 PM
b16a2pwr's Avatar
ALLJDM
no you would unplug the harness and make a jump (just another wire that would connect the two) thats all that you need to do.
I think something a little easier would be to make sure that you have enough Radiator fluid in the system!
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Mar 17, 2002 | 02:08 PM
BRT OVERKILL
yeah dont cut them jump them....
Boosted 00 Si
N/A 93 HB b16/18
Old Mar 17, 2002 | 03:56 PM
88EFSiR1J1's Avatar
oh no I wouldnt cut them why would my radiator fluid effect the fan?
14.729 @ 94.79
Old Mar 17, 2002 | 06:16 PM
88EFSiR1J1's Avatar
well kiddies I was going to wire it up like you guys said but when I look at it THE FUCKER ISNT EVEN PLUGED IN!!!! now I have 2 plugs thatll fit in it one came off my A/C fan and it is green the other is a plug that I found just dangling there in my fender but it is white although my best guess is the white one it doesnt seem right that a white plug would go with the green fan plug. which one do I use?!?!?!
14.729 @ 94.79
Old Mar 17, 2002 | 07:45 PM
svtjesse's Avatar
One is got your A/C condensor and one for you Rad. fan Plug one into the Rad. fan see if it works if it dont plug the other one in process of elimination
Jesse
Old Mar 18, 2002 | 02:05 PM
88EFSiR1J1's Avatar
yea i tried that but now I cant get it to come on dont know if its not hot enough or not the right plug Ill play alittle more with it today.
14.729 @ 94.79
teg2gen
Mar 8, 2001 03:36 PM
