EF Coilovers on EG
Old Sep 5, 2009 | 10:02 AM
MightyMaxGS-T's Avatar
Default EF Coilovers on EG
Can coilovers (real coilovers, no ebay sleeves) from an ef fit an eg? If not what are the differences...
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Sep 5, 2009 | 11:22 AM
Kung.'s Avatar
I have Tein basic coilovers if your looking for some ef coilovers!
Im not sure about if theyll fit egs, Id like to know too!?
Old Sep 5, 2009 | 12:34 PM
rangcrx's Avatar
engine building &best
no its the diameter,ef are smaller you may have binding problems and if coilovers i dont even think the sleeve will fit over a Eg strut
i love AUTOZONE
Old Sep 5, 2009 | 01:37 PM
Can anyone tell us the inside dia on each of the springs?-Bob
Old Sep 6, 2009 | 12:41 AM
The diameter of the coil springs are exactly the the same the differences will be in the shock body and how they mount on the suspension on the car.
Old Sep 6, 2009 | 03:43 PM
FrodoGT's Avatar
Found the Vtec switch.
Yeah almost all coil-overs use a 2.5" inner diameter spring, but youll find the EG has a different width for the mounting on the bottom and the top hats are different. Also they are different lengths so you car will likely be far too low even at max adjustment. The shocks are also valved for a lighter car and so are the springs.
TR Old Skool EF Crew #24
