B18B1 Help!
Old Sep 2, 2009 | 03:38 AM
DenSi's Avatar
Exclamation B18B1 Help!
I changed my oil lastnight and now my car wont start after i ran it. i was running it and i pushed it to about 5kRPM's and it started bogging and it just died. we thought it was the battery so we let it charge from another car battery but it still wont start, we tried to start it from a roll and it didnt work. any ideas on the problem that might have cause this? nothings leaking or anything everything seems fine in the Engin bay, it's just it wont start.
Thanks in Advance.
Old Sep 2, 2009 | 05:02 AM
Old Renegade's Avatar
Cool Runnings
chech for spark, may be a dizzy related issue. take of the dizzy cap and make sure the rotor is on. also what chasis is the car ef, da, eg, dc, ek and such..
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Sep 2, 2009 | 05:18 AM
extatic002's Avatar
is an asshole
did you put the drain plug back in?
Originally Posted by The Kyle
I quit every time I run out.
Then I quit quitting every time I get more.
Originally Posted by Clawhammer
As a general rule of thumb; if I can't fix it with a hammer it must be an electrical problem.
Old Sep 2, 2009 | 07:32 AM
Nandosol's Avatar
Garage Slut
CELs? Does it turn over at all?
spark/fuel/compression
Old Sep 2, 2009 | 12:35 PM
rangcrx's Avatar
engine building &best
like they said not sure why you would but if you took the spark plug wires off did you put them back in the right order?
i love AUTOZONE
Old Sep 3, 2009 | 06:17 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
did you use synthetic? you could have oil in the combustion chamber due to old rings, and putting new (syn) oil will cause it to get past the rings and to bog and run like shit. try pulling the plugs and checking to see how fowled they are and stick a light in the combustion chamber to check for oil.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Sep 8, 2009 | 02:20 AM
4DRintegraT's Avatar
check your grounds coming off the wiring harness... and like stated above.. spark and fuel. then if ur gettin both of them. check the compression
Rep is Returned
Acura
