Del Sol Fuel Pump Help!!!!!
Old Aug 31, 2009 | 12:51 PM
abadgsr's Avatar
Default Del Sol Fuel Pump Help!!!!!
Ok, so I have replaced the main relay with a known good used one, it clicks now, but still no fuel pressure. I can run jumper wires to the pump (out of the car) and it runs. What the hell else is in this circuit? I am beyond perplexed. This is on my dad's 168k miles daily driver, no mods at all, so any advice will be much appreciated!!!
Thanks for reading....
Old Aug 31, 2009 | 02:03 PM
mtber's Avatar
Have you verified that the ecu is good ?
Old Sep 1, 2009 | 10:03 AM
abadgsr's Avatar
No, I have not, have you heard of an ecu doing this before?? I guess I will have to try to source an ecu to troubleshoot it....shit.
Old Sep 1, 2009 | 10:30 AM
Nandosol's Avatar
Garage Slut
wires bad, bad ground
Old Sep 1, 2009 | 05:11 PM
eightwun3zfynest's Avatar
sleeper
like nando said above could be those.. check all your fuses, connections, check for burnt wires .. theres alot of stuff it can be..
Old Sep 2, 2009 | 03:43 AM
abadgsr's Avatar
thanks guys, i will work on this as soon as i get a day off work! appreciate the help.
