Turbo sizing...need some input
Sounds like a wastegate or bov issue. What kind of bov knock off did you get? if you can, take the bov apart and put washers in the spring seat just to see if the leak slows or stops. also, i have seen this issue with internally gated turbos, cheap internal gates are notorious for crazy boost regulation issues. just a heads up tho, when going turbo good quality turbos, wastegates, and bovs are critical to a good running and reliable turbo car.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Well I am using an external wastegate. It is a godspeed one and works pretty well. The BOV is a RFL knock off one. I already shimmed it with 2 washers. It may still be the blow off valve leaking though but like I said it will hold 7psi fine from like 3krpm to 5.5krpm then it starts to bleed off down to like 6psi. I have been very busy with school and haven't had time to leak test the system. Hopefully the clutch goes in today and I can also leak test today or tomorrow.
oooh the godspeed gate isnt bad at all...that bov leaks like crazy, i tried to use one on a turbo audi i did a couple years back, it sucked. i had the same issue you are having.
