white boxes w blk wires??? help
Old Aug 25, 2009 | 07:58 PM
sullivanracing06's Avatar
Default white boxes w blk wires??? help
im currently doing a wire tuck on my da and i have both the pass and driver side harness un wrapped and i noticed of all the grounds comming from the lights are running in to these white boxxes along with a few wires comming from inside the cab. if i eliminate these small boxxes and ground the blk wire to the body on a clen contact point will that work fine?
are the white boxes just a bunch of grounds that run into one good ground?
need input! THANKS!
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Aug 25, 2009 | 08:03 PM
custom240sx's Avatar
DC Crew Member #1
Those are just a way for honda to make a bunch of grounds hook up with one bolt. You can do whatever you want with the grounds so long as they are grounded somewhere.
Old Aug 25, 2009 | 08:16 PM
thank god! im done with the drivers side and its super clean! extended all of the light wires and working on a/c wiring a little bit longer tonight and will finish tommorow mornign before classes. the b20 should show up at 2 and will be in soon after n then i can tuck the engine harness and hook up the a/c compressor
Sullivan Racing LLC
352-665-2496-Tom
