Please Help!!!!OBD2a-OBD1????
Old Aug 25, 2009 | 06:54 PM
94TegDc's Avatar
Default Please Help!!!!OBD2a-OBD1????
Hey Tr I am prob. gonna purchase a 98 Integra this weekend. I have a 94 integra with a jdm gsr. I will be using that motor and tranny. I want to convert the 98 to obd1. Can I use my engine harness, injectors, distributor, and alternator? What all do I need to purchase to put my 94 gsr in the 98 car?
(Also, my 94 gsr is running now)
Thanks TR! -Donnie
Old Aug 27, 2009 | 03:26 PM
DRMORTY's Avatar
Once Ruled The World .l..
WRONG AREA
This area is for PROJECTS, I am moving you to TECH AREA which is correct.
TR
"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
Old Aug 27, 2009 | 04:34 PM
StreetBlitz's Avatar
B Tuned CRX
Swap everything you said into the 98`. But on your 94' on the passenger side remember to remove the tail of the harness that goes to the ecu. Use the 94` computer and take the o2 sensor by the cat off, and plug it. With the cable tranny going into the hydro. IDK? Never messed with that. Someone help with some info.
Old Aug 27, 2009 | 04:35 PM
SuburbanNoize's Avatar
Cold Ass Honky
Get a hold of Neal Sutton. He just made us a complete harness putting an OBD2 Engine to an OBD0 Car, and converted it to OBD1!
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old Aug 27, 2009 | 07:37 PM
mtber's Avatar
Yes
Old Oct 22, 2009 | 03:20 PM
EconoBox's Avatar
Four Door Mafia
Use all of your stuff and then hit up mtber for a conversion harness from your ECU clips to the OBD1 ECU. Look around on his site and you'll be able to find everything you need to make it work without doing any crazy cutting like some people do.
ECU Chipping, Tuning, Custom Wiring, and any other automotive needs. PM me for a quote.
Hmotors/Hondata/Hasport/JHPusa/PasswordJDM
stores. Most parts in stock or 1 day away!
Old Oct 22, 2009 | 04:54 PM
Nandosol's Avatar
Garage Slut
Its obd1 on a 94, should be a hydro transmission.
What tranny do you have guy? Do you know?
