SS brake lines for 88 CRX
Thanks guys, I actually did some searching on line and they said to use the ones for the 90-91 with the DC rear disc conversion, theres not much of a difference. I ordered thema few days ago, so they should be here tomorrow or the next day.
+1 ... <3 them when out on course
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
^ yup my setup is steel braided brake lines all around. crossdrilled front rotors, crossdrilled and slotted rear rotor, semi mettalic pads all around, integra da spindles in the front and da rear disc swap, booster, master cylinder and proportioning valve...man i tell you i swear you could get whiplash from the stopping power....
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
WOW! I didnt know they were going to make that much of a difference!
^ yup my setup is steel braided brake lines all around. crossdrilled front rotors, crossdrilled and slotted rear rotor, semi mettalic pads all around, integra da spindles in the front and da rear disc swap, booster, master cylinder and proportioning valve...man i tell you i swaer you could get whiplash from the stopping power....a
i have cross drilled and they were great at Sebring
for autox ... well in reality let's face it we aren't out there long enough for them to really do the job they are meant to do and i <3 throttle steering and trail braking
back on topic ... he he he
might as well upgrade your fluid as well . i am currently running Super Blue in one and Motul in the other
...91 SMF SCCA
yeah, forgot about that i run valvoline synthethic in mine.that has a higher boiling point than regular brake fluids.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
