h22 timing question. pic
Old Aug 16, 2009 | 01:47 PM
eightwun3zfynest's Avatar
sleeper
Default h22 timing question. pic
is it possible for a piston to had hit the valve from the timing being off and trying to start it? a friend of mine that is a mechanic said that it is possible. the number 1 piston is up.
Old Aug 16, 2009 | 07:41 PM
Nandosol's Avatar
Garage Slut
Yes the h22 is an interference motor.
If this did happen your motor is shot/in need of a rebuild.
Honda Civic Notched Piston Photo
Old Aug 16, 2009 | 07:42 PM
Nandosol's Avatar
Garage Slut
I really hope this didnt happen to u bro.
I was looking forward to seeing your sol in action.
Old Aug 16, 2009 | 07:49 PM
sleeper
i know me to. i hope it didnt.
Old Aug 16, 2009 | 07:50 PM
sleeper
will notching the valves interfere with compression?
Old Aug 16, 2009 | 08:07 PM
Nandosol's Avatar
Garage Slut
they notched the pistons not the valves and yea these are higher compression pistons they used on that link(jspec type s pistons) i gave you
I dont think the notching affected compression. Then again i dont know, you would have to ask someone that has experience in those things.
Old Aug 16, 2009 | 09:29 PM
sleeper
o ok ..
Old Aug 17, 2009 | 03:33 PM
Blue92ludesi's Avatar
Its a 50 50 chance that ur fine , fix timing start it n see
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
Old Aug 19, 2009 | 01:49 PM
AccordMike92's Avatar
Yoo!!!!!
looks like one cams miss aligned
Old Aug 19, 2009 | 07:27 PM
sleeper
not to be an ass but i know its off timing .. the question was from it being off timing is there a possibility one of the pistons hit the valve.
