map sensor issue..
Old Aug 14, 2009 | 03:18 PM
Jogunz's Avatar
Default map sensor issue..
i had a check engine light on and i pulled the code. it turned out to be the MAP SENSOR.
heres the thing. i swapped out the old motor cause the miles were high. i put the same motor but from a different car into my car. Everything is fine except for the map sensor.
There is nowhere on the throttle body to put the map sensor on. but on the old motor (the 1 that is out of the car) the map sensor was on top of the Throttle body. where do i put it then? im using alot of gas and its burning alot of gas as well.
please help me out here. Thanks
-Jones
Old Aug 14, 2009 | 04:11 PM
Jogunz's Avatar
any1? please. theres 33 people viewing this section right now and no1 replied yet? lol 0__0
Old Aug 14, 2009 | 04:13 PM
Blue92ludesi's Avatar
Can you tell us what kinda car you got?
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
Old Aug 14, 2009 | 04:27 PM
Alpha's Avatar
Three way tee into a vacuum line and run a line to the map sensor
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Aug 14, 2009 | 07:33 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
+1.
Old Aug 15, 2009 | 01:29 AM
Jogunz's Avatar
your a life saver. Bought that 3way piece and an extra vacum hose. issue solved. thanks bro.
Old Aug 17, 2009 | 11:58 AM
JDMSeon's Avatar
Default 1994 hb
yoo do u have a left sd fender 4 a eg hb
