tech question
Old Aug 13, 2009 | 08:25 AM
clean teg's Avatar
Originally Posted by Nandosol
ouch expensive thing to pay for just for being pissed
yup
Old Aug 13, 2009 | 11:15 AM
luvsracin87's Avatar
turbo hhhmmmm?
Do another compression test but this time put a cap full of oil in the number 1 cylinder. If the numbers come up signifigantly then its the rings, if it stays a 135 then most likely a valve.
Steve: (813) 810.4146 <~ call or text
Old Aug 13, 2009 | 01:05 PM
clean teg's Avatar
what will a cap of oil do????????
Old Aug 13, 2009 | 03:44 PM
custom240sx's Avatar
DC Crew Member #1
Helps seal the rings temporarily. If the rings are bad it will boost pressure way up in the cylinder. If the valve is bent it will most likely stay the same pressure.
Old Aug 13, 2009 | 04:09 PM
clean teg's Avatar
no it changed alot it went from 135psi to 225psi why such a jump??
Old Aug 13, 2009 | 04:27 PM
Nandosol's Avatar
Garage Slut
because your rings are bad
Old Aug 13, 2009 | 04:34 PM
  #17 (permalink)
DC Crew Member #1
You probably cracked a ring
Old Aug 13, 2009 | 05:09 PM
  #18 (permalink)
clean teg's Avatar
well if there is a cracked ring wouldn't it lose pressure not gain it by adding oil? shouldn't seep down the cylinder wall?
Old Aug 13, 2009 | 05:37 PM
  #19 (permalink)
omgwtfbbq!'s Avatar
I race sailboats
The oil seals the ring temporarily, increasing the pressure. This trick helps you identify if its a ring problem or a valve problem, because like has been said before if its the valve the pressure won't change.
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old Aug 13, 2009 | 07:34 PM
  #20 (permalink)
Willis's Avatar
yep looks like your rings are shot on that cylinder!
